hi this hayter harrier 56 is the newer model with b & s 850e motor . it starts first pull and runs perfectly all day if not stopped but then will not start until called down and then starts first pull .compression is very good when cold and the same when hot . I tested spark with tester and spark jumped gap easily when hot or cold . I have no experience with the carb on the 850e any advice please thanks
