Greetings,
Without warning yesterday, I was mowing and when I released the clutch drive bar the cable was slack, and the wheel drive would not disengage. I had to shut the engine off to get it to stop. The mower will manually roll forward, but not backwards.
The cable is not broken. In fact, when I turn the mower over, I can pull on the end of the cable that attaches to the transmission, and the cable and clutch bar at the handle will move back into position. Further, when in this position the mower will manually roll BOTH forwards (ratchet) and backwards until I engage the bar again. (I believe) with the cable in this same position, the mower will also no longer have the wheels engaged to the engine, but I have not proven this.
It seems to me like perhaps a return spring of some sort has broken, been lost, or somehow disengaged. I have some pictures, but can't seem to see vey much without some disassembly. Does anyone have a parts diagram of this particular model?
Any thoughts, comments, suggestions welcome.
Thank you.
Thank you.
