Groundsmaster 224
Sailor
Carburetor problems. Mikuni carb toro part 72-6260 is not functioning and everything is discontinued. Is ther a substitute carburetor
Any carb from an engine of the same capacity will be fine.
Getting it to mate with the governor will be the problem.
The mounting holes for most mower engines is fairly well standard.
As for a drop in and hook strait up carb, have no idea but I do regularly fit different carbs.
