grease
2ball
  • John Deere Multi-Purpose HD Lithium Complex Grease
  • Grease-Gard™ Premium Plus
Is there anything special about this grease? Can I use any grease? I have marine grease, can I use that?
and
do I use one of the other or do they each have a different purpose?
FWIW I use lithium marine grease almost exclusively as it weathers better ( or rather resists weather ) than most greases
The JD grease will probably be better than the auto parts store grease but no reason not to go with what you have on hand.
As long as you are not mixing lithium base grease with polyurea based grease then not a problem
D
Deleted member 97405
Guest
I use John Deere's blue grease TY24425. It's made for high speed applications (spindle bearings, etc.), plus it repels water, which is great for non-sealed joints such as steering spindles.
