Hi guys!
Let me give what info I can and see if it can help you in knowing what my problem might be. A couple of weeks ago I went to cut my grass and it ran about 5 minutes and then the motor killed. Now the it won't stay running, unless the choke is on, and even then it try's to kill until I wiggle it back and forth. It is of my opinion it may be one or more problems from the following list below.
1. Since I can keep it running by wiggling the choke, the carburetor may not be getting enough fuel when the choke is released.
2. A gasoline line leak.
3. A vacuum leak.
4. A dirty or bad carburator.
5. The gasoline caps are not holding a vacuum.
6.Moisture in the fuel tanks
7. Trash in the fuel tanks.
* Take not that at first I thought it might be bad gas, so I tried putting Sea Foam in what gas I had left in the tank be I still have the problem. I also changed the fuel filter, and checked to see if fuel ran pass my fuel filter, and it was pumping though.
What do you guys think is my problem?
3. A vacuum leak.
