niklndymer
- Jun 14, 2016
- 1
- 1
Hello. I am new here and in need of some help. I have inherited a Gravely 8102 rear-engine rider and have been readying it for use. I have dealt with all the typical issues of long storage but could use some advice. The PTO lever at the transaxle is broken and I obviously need to remove it to repair or replace. The problem is that the clutch hub on the #2 shaft (reverse clutch) interferes with the removal of the PTO lever.
What is the removal procedure of the hub, if it can be done? Also, what is the recommended epoxy (??) for bonding the friction material to the opposing clutch face?
I am quite experienced in small engine/auto and related repairs and have a quite-thoroughly equipped shop.
Thanks for the help.
