qualitylawn
- Jun 8, 2012
- 1
- 2
Grasshopper 725D will not shut off when I put the key in the off position. Suspect a fuel solenoid but was hoping for some input and suggestions. Thanks in advance for any help
Please define "will not shut off". Do you mean continues to run, or takes a long time to stop? If it continues to run you will have a loose wire that kills the coil. If it takes a long time to stop running then you are on the right path with the solenoid on the fuel bowl.
