could someone tell me how many amp stator i have thats located behind the fly wheel. my mod. # is350447 type # is 1195-e1. and if you know the pt.# that would help thanks :smile:
Results engine operators manual & parts list, see page 11 in parts list, you will need to remove your stator & locate part number on stator in order to purchase correct stator as several are listed. Your part number is 696458, code number 1195 not listed so your stator, alternator, will be the one that does not have code numbers listed. Item 474D part 696458 10-16 amp regulated page 26.
