Had disassembled top half of engine to overhaul carburetor and reseal intake runner because of no-start problem, after ensuring I had spark, air, and got it to run on starting fluid. Had to disconnect governor lever to unhook linkage; referenced marked the gov. shaft before disassembling. Reassembled - now it runs full speed only. Probably changed an adjustment somehow. Time to start from square 1......what's the step by step?
Dan L.
Dan L.
