This post is for a GCV160 Pressure Washer.
Detergent was accidentally put into the gas tank and the motor did run until obviously the detergent made it's way in. I had flushed the gas tank and the carburetor and got it to run. After leaving idle for 3-4 months it will not start. I did change the plug. Also I checked that it is getting spark.
I'm wondering if any detergent residue may have damaged gaskets, etc.
Any ideas on how to fix this? Would I have to rebuild the carb for example?
Thanks for any advice!
Rob
Rob
