Hi I have a 2005 Try Bilt Bronco, 13AT609G766, with a Briggs and Stratton 18.5Hp motor.
When I park the mower in the garage, there is a reek of gasoline that fills the air.
The gas level doesn't seem to be noticably going down, so I am thinking a may be a bad gasket.
Is there a common point of gasket failure on this motor? Don't want to start dismantling it without a plan as the mower runs fine.
Any suggestions welcome.
Thanks RS.
Thanks RS.
