humphrey1989
- May 1, 2014
- 7
- 28
I have a Poulan 2450 chainsaw and need to know what the gas line setup is. What I have now is (If you're looking at the chainsaw from above and standing behind it) the hole at the top right, which has a large line in it- goes to the bulb and then a small line goes from the bulb to the bottom left of the carburetor. The hole at the bottom left has a small line that that runs to the top right of the carburetor. The small line running from inside the tank to the carburetor directly has the fuel filter on it.
Is this correct?
Is this correct?
