How do I check if the charging circut is sending a charge back to the battery.
The mower runs fine & starts when the battery is charged but the battery discharges with use.
the battery indicater light comes on when I put on the lights or engage the mower.
Stater has no output till I hook it to regulater & the I get 13.5 volts from regulater terminal to ground.
Can't find the charging wire back to battery unless it charges thru the fuseable link.
Any ideas??
Any ideas??
