Fuel tank outlet "Grommet"
Mick Oz
My mt830 seems to share parts with a Simplicity mower, can anyone recognise this fuel tank as I could use a replacement rubber grommet for the outlet pipe.
The tank hole is ID is 0.545" or 14mm.
The metal rightangle fitting is 0.402" or 10.2mm
The inner sleeve of the rubbber grommet has completely gone so I now have no way to keep the metal fitting inplace.
The nature of the plastic that the tank is made of prevents any glue I have tried from bonding to it.
Mick Oz
A wider view of how the mower looked before a previous owner removed and lost the hood.
That grommet is used on the older Toro/Wheelhorse tractors. Still available, but I'm sorry I don't have the part number available now. A good Toro dealer should be able to get one for you. I won't be in the shop until Tuesday, so if you cannot find one, PM me Monday and I'll try to remember to get you the number on Tuesday.
Mick Oz
Thank you Rivets.
I will have a search online referencing Toro parts.
Mick Oz
Boobala thank you for the link, but it only takes me to ebay, not a specific product.
I have scrolled through some ebay options but the ones that look right dont show dimensions. I will look again and see if any say they suit the older Toro models.
