Anybody have thoughts on using a product like Permatex Aviation FORM-A-GASKET liquid sealer on small gaskets and hose connections? Comes in a four ounce can at NAPA. I'll be down there next week to get some Tygon tubing.
Well it all depends if you want to repair it or destroy it.
If the lattr, the do it properly with a 1/4" bead of silicon on everything.
If that does not work the wrap the whole thing in duct tape and give it a liberal spray with WD 40.
Now I have your attention and just before you send me an abusive flame, how about some better description of what your problem is.
Won't prime means what ?
Primer bulb will not fill with fuel ?
trimmer will not start ?
Did you really buy a new carb, the pull the new carb apart & refit the gaskets oiled ?
If so what on earth made you do this ?
If the new carb did not prime then you take it back for a refund, or try to find the
EXTERNAL REASON why it is not working ?
Did you suck on the fuel delivery line to ensure fuel was flowing through it ?
Did you pressurise the tank to test he integrity of the tank & fuel lines ?
do you have the basic tool needed to work on cube carbs, including a vaccuum / pressure tester.
Did you do the work in a very clean room on a clean table covered with clean paprer ?
