FS 250 trimmer throttle cables/springs diagram ?
FRD1952
I had to replace the plastic sleeve that holds the engine onto the drive shaft/pole as it was torqued too much with the blades on and it broke. NOW I can't figure out how the cables/springs go back inside the handle (regular handle/throttle right on the main shaft) to put it back together. Anybody have the diagram on how these 4-5 parts to back into the handle to let the throttle, start/stop interlock slider button, work properly ?
Thanks,
FRD
