Fritzel
fritzel
Craftsman leaf blower will not start. Carburetor has been cleaned and all new parts, also fuel line and filter. Spark plug is getting fire. It appears that there is no fuel getting to the carb. Any Suggestions?
Have got it to fire by removing the plug and squirting a little quick start in it , but that's it.
pugaltitude
Have you set your needle and lever in your carb? Set it with a straight edge or "W" guage depending on type.
What carb?
Possibly torn gasket not sealing in the carb.
Possible diaphragm?
Possibly exhaust is blocked.
Remove and heat up with oxy/ectylene gas to loosen the carbon build up.
When the exhaust off look in the port for damage to cylinder, rings and piston.
