flywheel keys keep shearing.
bebuzz69
i have a 10 horse tecumseh and every time i pull the starter i shear a key.
what would cause this. i spin the cam by hand and everything is free.
If the keyway in both the crankshaft and flywheel are good, the main cause for shearing would be not properly torqueing the flywheel nut.
bebuzz69
never heard of that, usually just use impact wrench to tighten.
oil/grease contamination on the crankshaft/flywheel taper can also contribute to this problem.
You have most likely damaged the key ways.
Check them for burrs and if burred take to them with a fine file.
Then a bit of lapping with some fine valve grinding paste till the whole contact faces is a dull grey.
Careless use of an impact wrench will shear the key, they respond much better to a slow tightening
SeniorCitizen
By using a impact you may have cracked the flywheel.
Rocky J
Been awhile sense I worked on a Tecumseh but didn't they have a off set key in them? If so try putting the key the other way next time and try it, it might be timing kick back.
It is a tapered offset key so will only fit one direction.
bebuzz69
No this has a woodruff key.
bebuzz69
also i pulled off the flywheel and the key did not shear this time, but it has a kickback like its out of time. so i pulled the pan and the crank gear and the other gear line up right on the marks. so iam at a loss as to why it is out of time.
