I got this mower and it ran but had a oil leak. I didnt run it long and dont know small engines so it went to my repair guy who lives in my neighborhood and repaired the oil leak in my John Deere 14PB cheap...
anyhow he tried to fix it but discovered the leak was not what what he originally thought and he gave me this news today, this was his exact wording: "bad news, not the oil pan. crankcase vent hose was off the air cleaner .excess crankcase pressure caused by blow by was causing oil to be expelled thru the vent hose , so you need a new motor or overhaul this one"
I asked him what parts exactly we need as this previous text meant zero to me.
he got back with me and said I need rings , rod bearings and gaskets.
he is a good guy and he is cheaper than repair shops but he has been repairing this stuff for decades. former John deere mechanic he now is self employed . I trust him no issue there.
what I need to know is it worth fixing the motor or finding another motor or just not fixing it at all? I actually like the HOnda better than my JD because it has more power and newer. for the 10 minutes I used it it worked better for me than the JD.
I read all the time " its not worth fixing and you should by a different mower" he will be getting backl to me tommorrow with cost to get it "overhauled" ....
just looking I found this motor for $150. I Just dont know if this willl work on my mower. I know they use Honda mowers on a variety of stuff..
Honda GCV190 Engine for Pressure Washers | eBay
