First cut of the season should be super low... That way the yellow perenial line is well below the green line when the growing season kicks off. Allows for greener lawn and better stripe. First cuts generally don't look very good but hey neither does the grass
Good to know! That it was I thought. I can't mow much lower. I tried, but the grass was just too yellow so I had to raise my mower.
If your cutting nothing but yellow on the first cut that's good.. say that yellow line is at 2" you cut it down to 1 3/4" in a few weeks you cut at 4" that gives you 3 1/4" inches of green you can look at it from any angle and it'll be green
