Alan Gerecke
- Aug 29, 2014
- 2
- 3
My FD620D Has on injector pulse What test should I preform? I do have fault codes water and air temp sensor but this should not keep the injector from pulsing correct?:confused2:
I have read a lot about this error and most are having problems with map sensor that is not showing an error. The other sensors are bad as well if you are getting an error on them. You can check by unpluging the bad sensors and trying to start. If it starts then map is ok. If it does not them map is bad.
