Fc540v rebuild help would be appreciated
Ean
Today I started the 180 it ran fine for a minute then started knocking so I cut it off so it needs rebuilding already it had 75 psi compression I have never rebuilt an engine before what would this evolve please reply so I can get what I need do do this
Ean
I took the plug out and spun it it did not make a knocking sound it may be just running rough what do you guys think
Check the oil level, is it overfilled or low for some reason?
Ean
The oil is new and I right at the full mark when I put the plug back in it made the knocking sound
