Have an F935 that the PTO won't engage with the switch. The solenoid that retracts the PTO brake band and engages the shaft is free to move, has power going to it when switched, but doesn't engage. If you manually move the solenoid it will engage and keep the PTO running until you shut the switch off, then it disengages as it should, but won't re-engage unless you manually push the solenoid shaft again. Any ideas? It almost acts like one of the safety interlocks is preventing engagement, but power is getting to it, so that shouldn't be the issue. Maybe just a bad solenoid? I'll pull the switch next and see if it's got an intermittent problem, but again, power seems to be getting through. I'm open to any suggestions.
Patrick
P.S. This year obviously has the PTO switch, not the manual lever/magnet combo on some F935s.
Patrick
