Hello everyone,
What is acceptable compression range for the "F" engine?
Also, after my mower has sat for a month or so, the only I can keep it running is by putting my finger in the carb opening and almost completely blocking the airway, for several minutes, until the engine builds some heat. It starts with 1 or 2 pulls and once it stays running, it's performance is rather weak....
I have taken the carb off and disassembled several times to clean it and it looks fine. I tried different float adjustments and no help.
Could the carb be warped? Since it is plastic, maybe it is shot??
Any help would be appreciated...
THX...AL
THX...AL
