hey everyone im andrew konowaluk 20 years old been landscaping and mowing grass for 5-6 years now but anyway picked this mower up to replace my old 52" bob cat and 48" farris walkers. mower looks to be in ok shape it has 1500 hours start runs great but the only issue im having is (and i knew this when buying) it needs a main axle seal for the left wheel motor has a slow leak (the wheel is covered in oil) i did order wheel motor rebuild kits but looks like it was the wrong kit (for parker wheel lmotors) but any way just want to run a few things past you guys see if anyone has more experience then me in this area
First off is my mower a 2008 or 2007? or some other year?
heres the sticker under the seat..
second will a parker seal kit work on a non parker wheel motor?
(i know they probably wont but hey worth a try)
third is my wheel motor considered an HGM-E serries?
(heres the numbers off the back of the pump)
also can someone post a link where to buy the wheel motor seals?
cant think of anything else right now but if i do ill be sure to ask but heres the mower thanks guys!
