Today I spent time online studying ethanol. Here are the facts which seem relevant to this forum, IMO.
THE MIX: The ethanol is mixed in a "dry" form with gas which results in a uniform blend. Water is
not present as a separate liquid. But ethanol will attract water and it WILL EXIST AS
SLUG AMOUNTS OF WATER separate from the gas mixture in your tank/lines
depending upon the blend (E10, E15). Tight containers and short storage time important
STARTING: Ethanol does degrade starting, but not supposed to in the US. This is not due to the
water issue, rather inherent to the ethanol.
CORROSION: Ethanol is a scouring agent and will loosen materials which gasoline won't. This crud
will circulate until it is eliminated. Perhaps frequent gas filter changes for a year?
Ethanol destroys oxide layers. Think anodize and think natural film aluminum produces to
protect itself. Also ethanol increases (electrical) conductivity. Think electrolyte as in a
battery. These processes probably produce crud which clogs fuel systems.
HEAT US Dept Energy study. Exhaust gas temp increases 20 C with E15. (No wonder the heads
get hot). Piston heads were softer. Piston pins showed 6% hotter color.
MPG Fuel consumption for E15 is 10% higher due to reduced torque.
EPA Your government has "gwaranteed" safe use of E15 (15% ethanol) for all cars and small
motors from 2001 and later including two strokes. That should mean
the materials and components are ethanol proof. Prior to 2001 all bets are off I guess.
I stopped reading after a couple hours on line. I can post some of the sites or just type in ethanol
yourself for reading pleasure.
