Engine replacement
Bill M.
Hi everyone, new to forum and have a question. I would like to know if I can replace my cracked Kohler courage 21 SV610-0020 with a SV620-3210 engine. Will the bolt down holes line up? The two engines look the same and everything is the same size. Only difference I see is the difference in HP. Can any help me with this.
Bill M.
The main thing to check is crankshaft length and diameter. Make sure both are set up with or without fuel pump. Other than that everything else should be adaptable.
Bill M.
Everything is the same, just wanted to know if I had to do any drilling for the bolt down bolts. I know some engines are found on different zero turn lawn mowers.Would love to replace the Kolher with a Kawasaki, but it's made a little different.Thanks for your help.
