Hi all,
First post, so greetings. My Mountfield (details in sig below) suddenly cut out this morning and wouldn't restart despite turning over. I checked the fuel supply which is fine, and in the process spotted that an orange-ish wire had become detached from a small 2-pin connector (other wire is black to ground) on a small cylinder attached to the bottom of the carb. I need to remove the female pin in the connector which is a pain in the armpit, as the wire has pulled out and left the small pin inside.
Anyone know what the connector is connected to on the carb? And are there wiring diagrams available?
Thanks.
Thanks.
