I recently attached a new set of Gator mulching blades to my Zero Turn Cub Cadet mower with a 50" 3 blade deck and am not happy with the results. It's the Lowes variety of Cub. First, it seems to build-up in the deck chamber and leave far too many clumps behind and I also get a streak (1" or so) left behind with each pass. I don't mow wet grass other than the moisture that is found in most grass when it is 3-4" high. I realize the Cub is likely not designed for great mulching, but I thought I would get better results than I am now getting. I cut high and often in the spring and it still clumps, etc. Does anyone know of a remedy, other than purchasing a better mower with a deck that is designed for mulching? I thought maybe I need to do some adjustments that I am not aware of. Thanks for your replies.
