melvin1942
- Sep 17, 2015
- 4
- 13
I have a problem with the dip stick tube seal on my Briggs Vanguard 18 HP engine. I have replaced it 4 times once when I overhauled the engine and 3 times since then. 2 times I could not find any of the seal where they went I do not know. The last time the seal was there but was split. I would like to know what the tap size is in the block. I am going to try to make a seal that will last.
Model - 356442
Type - 0224-B1
Code - 09011911
Thank you for your time.
melvin1942
Model - 356442
Type - 0224-B1
Code - 09011911
melvin1942
