Grass Type | Mowing Height |
Bahia grass | 2½” – 4” |
Bentgrass | ¼” – ¾” |
Bermuda | ½” – 2½” |
Buffalograss | 2” – 4” |
Centipede | 1½” – 2½” |
Fine fescue | 2½” – 3” |
Kentucky Bluegrass | 1½” – 3½” |
Ryegrass | 1½” – 2½” |
St. Augustine | 2½” – 3½” |
Tall fescue | 2” – 4” |
Zoysia | ½” – 2” |
Depends on the type of grass you're cutting, most all grass from Bermuda to St Augustine have different cutting heights.
[TD]
Grass Type Mowing Height Bahia grass 2ス 4納/TD]
Bentgrass シ セ納/TD]
Bermuda ス 2ス納/TD]
Buffalograss 2 4納/TD]
Centipede 1ス 2ス納/TD]
Fine fescue 2ス 3納/TD]
Kentucky Bluegrass 1ス 3ス納/TD]
Ryegrass 1ス 2ス納/TD]
St. Augustine 2ス 3ス納/TD]
Tall fescue 2 4納/TD]
Zoysia ス 2納/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
Bentgrass シ セ納/TD]
Bermuda ス 2ス納/TD]
Ryegrass 1ス 2ス納/TD]
Zoysia ス 2納/TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
[TD]
Thanks... Guess now I need to learn what each type of grass looks like. Kentucky Bluegrass just seems so common up here in northern Indiana
Ric,
That's VERY good information...thanks for sharing that. Also, isn't the best thing to do is cut a little higher than the "minimum" and cut often(using the "1/3 rule" where you cut the grass when it is 1/3 taller than the desired height)? And if you are striping, wouldn't some of those grass types' minimum that are 1/4" to 1/2" be way too short for the striper to bend the remaing grass blades to get a good striping effect? Just trying to learn all the mowing insider info:0)
Ric,
You forgot Crabgrass = Burn it.:laughing:
