cultivator c410 will not run
ACF
have a craftsman c410 cultivator have no model data available but the unit has a 4 cycle engine when you go to start it will run for a second or two with starting fluid when dies there is a gargling sound from the carburetor not sure what would cause and what the fix is thanks
Should have have an engine model number starting with 143.XXXXX
ACF
found the tiller model number which is cmxgvamkc30c and partstree shows the engine break down , have tha1 stamped on carb
Should use MTD carb #751-16046-4. At that price of less than $35, I would be replacing the carb, instead of trying to rebuild it.
ACF
sounds good
