Hi All,
I have a Slt1554 cub cadet with a Kohler Command 27 engine. I can get it to start fine. I cant keep it running unless the choke is almost fully engaged when you put any load on it it dies it almost seem like its running out of gas. I have replaced the fuel pump and fuel filter the new filter fills with gas so i do not think that fuel delivery is the issue. If anyone has any suggestions or direction i should look in it would be appreciated.
Thanks
68vert
Thanks
68vert
