greynold99
- Apr 24, 2012
- Threads
- 16
- 87
When should you start thinking about replacing the Rear Tires on a Cub Cadet lawn tractor? I have a 16 yr. old HDS2135 and I looked around to see what the price of rear tires would be - turns out there around $150.00/apiece.
Why are they so much more expensive than equivalent non-OEM tires; which can be had for $60-$100 in the same size (20X9.0X8 and similar turf tread)?
My old tires aren't bad, a little worn but I wondered if they would dry rot out after so long and leave me stranded when needed.
thanks,
greynold99
thanks,
greynold99
