Cross reference for JD OEM seals.
AWA
I'm trying to find a FOR SURE seal cross reference for my JD 325 mower. The seal numbers are M806608 andM806655. I've searched the web til I'm blue in the face.
Is there a number on the seal, it would be the manufacturers number which you can cross-reference. You won't be able to cross with the John Deere part number. If that does not work take the seal to place like "Motion Industries" which sells bushings, bearing, seals, etc.
