mtfallsmikey
- Oct 17, 2012
- 4
- 12
I took the bagger from an LT 1000, mounted it on my White. Had to spread the side bars a bit, and take the shoulder bolts that the bagger mount fits on off the LT 1000, other than that, it worked. Problem is, it's not picking up very well (mulched leaves). The LT 1000 has an area cut out on top of the mower deck where the deflector mounts on, where the tube going to the bagger goes, the White does not, strictly side discharge, is the cutout on the LT 1000 there to give enough lift/air pressure to move the material into the bagger?
