jekjr
- Jan 3, 2013
- 271
- 1,969
I recently bought a Craftsman 16hp 2 cyl tractor.
I am not sure how old it is. There is a fuse on the left hand side under the hood right behind the dash. I have problems with that fuse blowing pretty often when trying to start the engine. The lights are completely dissconnected up at the front and the switch if off.
This fuse might blow once every 10 times I start the engine or it might blow two times in a row without ever turning the engine over. Does anybody know what all is on this fuse? Is it just for the cranking circuit? Tractor had sat up for a long time but after runing new gas through it with Sea foam in the gas it is running pretty good now.
