Craftsman LTX1000 Belt Replacement
Hydestone
Hi All:
I am looking for a LTX1000 manual in PDF format but can't locate the correct one online. Any suggestions where to look? I need to replace the belts and am looking for the specs on sizes etc.
Thanks!
You should be able to get one through sears parts direct. Have your units model and serial numbers on hand. They are located under the seat.
Hydestone
Unfortunately, the numbers are worn off. It’s a 1998 with 42” deck.
Can't confirm 100% but possible model number is 917272410 with the Kohler CV492 spec 27506 engine. See if that is the engine in your mower.
