Craftsman LT1000 19.5 Briggs & Stratton 2 cyl opposed
Roadhunter
  • / Craftsman LT1000 19.5 Briggs & Stratton 2 cyl opposed
I have a 2001 LT1000 with a blown 19.5 HP 2 cyl opposed engine. Will a 19.5 Intek OHV motor fit in this tractor? I am not sure if the output shaft is the same etc. Thanks
Output shaft is probably the same. Wiring may be different and may require mods. Exhaust will be different. May be able to use the muffler that you have, but will need different exhuast manifolds. Mounting pattern for bolts will be the same for both engines.
Roadhunter
Thanks a bunch. I couldn't seen to find any info on the B&S twin 19.5. All of the info I could find was on either the Intek, Kohler, etc. Cheers
highlander620
I have the repair manual on cd just what do you need. send me an e-mail address and i'll try to get it to you
DANMOWERMAN
HIGHLANDER620
I LIKE YOU HAVE A NEARLY UNKNOWN 2 CYLINDER OPPOSED B & S ENGINES. I WOULD APPRECIATE THE CD THAT YOU MENTIONED IN YOUR THREAD. MY E-MAIL IS
PACKARDFORMAL@GMAIL.COM
THANKS
DANMOWERMAN
