I was trimming some brush and the trimmer stopped running. I changed the spark plug cleaned the fly wheel and the coil it still wont start, I tried starter fluid and that didn't help, the coil seem to be firing, however, the compression seems to be low. The valves and the piston cylinder seems to be ok. There was a bit of oil in the cylinder and the plug was wet I cleaned the cylinder and dried the plug but it still would not fire. This is on a Briggs 6.0 Quantum engine. Thanks in Advance.
Bama49
Bama49
