tucker0104
- Oct 24, 2012
- 9
- 17
I recently replaced the fuel cutoff solenoid valve. There were two wires so it shouldn't matter which goes to which wire, right? It started after I put everything back together but didn't seem to run as strong as it did before. I mowed my lawn and after I finished mowing my lawn, I sprayed the mower clean. After cleaning it, I started it and it barely ran. I had it in full forward and it only crawled forward. So, the only things that I disassembled are the throttle springs but the engine seems to be revving up right so I don't think that is the problem. I am thinking a dirty carb. The model number is 917.276600. Has about 150 hours on it.
