Craftsman cmxgaah46bt Backpack blower
makomike80
Hello I'm looking to replace a throttle cable on my craftsman cmxgaah46bt Backpack blower. I've called Craftsman who said it is manufactured by Husqvarna. Husqvarna does not answer questions over the phone as of 01.2022 and their chat does not connect.
I'm looking for the correct part number of the cable so I can order a replacement. I assume there is a cross reference with a similar Husqvarna blower since the make it for other companies.
TIA for any help!!!
Mike
From the parts diagram that I found on the Husqvarna dealer only site. the closest you may come is the throttle assembly part number 594048201 but I can't find a picture to see if it contains the throttle cable or not. there is no separate parts listing just for the cable. It appears every item on that blower is part of a "Repair Kit" So everything comes down to assembly component replacement.
Maybe this will answer the question.
makomike80
I'll have to look close at mine. I'llget back to ya... Thanks for the info!!
ca035830
Hello, I believe this blower is manufactured by MTD. Attached is the parts list. The throttle cable is 753-06434.
Cheers,
John
  • 769-19612.pdf
