Courage 20 single no spark
DennisJM
Replaced plug and magneto but still no spark. Wonder if it has anything to do with the wiring that relates to the yellow wire attached to the magneto? Could I either disconnect the wire or ground it to bypass any issues with the wiring (safety switches failing, perhaps) I tried it both ways but nothing changes. Engine turns over fine but if I ground the plug to the block I can see no spark. Both the magneto and the plug should be gapped properly.
Disconnect the wire from the ignition module and crank engine with spark plug grounded to block and check for spark. No spark bad module If the new module test bad, I would be checking for battery voltage on the kill wire. Battery voltage shorting through that wire will kill the module instantly.
