have b&s 300 series. would not start. would run on ether only.cleaned out fuel tank and carb. started after using ether. turned off because forgot to tighten bolts on cover. will not start, not even with ether. here popping noise. spark plug good and sparking. any suggestions. fixing to use BFH to adjust it.
