gregjo1948
- Nov 28, 2012
- 76
- 364
Working on an 11.5hp I/C Briggs. The plastic recoil parts are broken, even the handle grip that you pull. The owner wants it converted to electic start because it pulls over so hard it breaks the recoil. I installed a stator,flywheel with starter ring gear and a starter. The engine has too much compression for the starter to roll it over. Now I see why he wanted it converted to electric start. My question is, why so much compression? Is there a compression release somewhere on this engine? Did Briggs put in the wrong piston or the wrong head. The owner says probably isn't 20 hours on the engine and it has always been mean to pull over. Any ideas would be appreciated. Thank you, gregjo1948
