ronnierepairman
- Oct 1, 2023
- 1
- 7
Hello,
I have a briggs 441777
Type 0283 E1
Wouldn't crank .. and barely with the plugs out.. so I got a battery.
Then it would crank with plugs out but hang up on the compression stroke..
So I assumed the compression release broke..
Took it apart and it looks like it doesn't have one.. I've never seen that before however I've only taken about a few briggs motors..
So does this not have a mechanical release?? If so, is it just an exaggerated lobe ?
If so I'd assume that the valve adjustment is critical and is probably the problem??
Type 0283 E1
