Compression issues
Djames210
Hi, can someone tell me the correct engine compression on B&S model 31P877? The lawn mower is a JD 115. Thanks, darrin
Do to the compression release there is no way to get an accurate compression. The standard procedure is to do a leakdown test to check for leaking components that will cause low compression.
Forest#2
Wondering why you ask?
Are you having starting/running problems???
