1984???
Old damn mower. Yeah, the info in your last post should have been in the first one. You can pretty much bolt up anything you want, as the base
mounts are pretty standard, which is why the mowers came out with several different brands, you can repower with any brand you want, go to these warehouses and pick up a phone, they will hook you up, hell they probably have an engine category for your particular tractor, your main problem will be matching the alt/electrical.
