gravelyhead
- Oct 21, 2014
- 1
- 6
Briggs and Strattion fans I have a 16hp single cast iron block model 326400 Synchro Balanced Engine that needs the Ex. valve guides reworked I ordered the # from the book 231218 replacement guides and these are a really thin walled bushing. This so called commercial / Industrial engine does not have replaceable guides that can be pressed out ! I think the replacement sleeves are 9mm in dia. and i need to bore the exsisting worn out guides round on the exsisting location and finish them to size with a reamer . Is there a better way ? Thanks
