I have a John Deere la125 with a Briggs and Stratton 21 hp engine. Unfortunately after only 100 hours with scheduled maintenances performed, the head gasket failed. The Mower started burning oil and you could hear and see smoke from a drip of oil into the combustion chamber.
I decided after doing research it was a job I'd tackle myself to learn about the engine and save cash. After I was done - the moment of truth... Fire it up! I immediately noticed the mower was quite a bit louder than before. It wasn't smoking any more, so I decided I'd give it a go and see what happens. If it blows I'll buy a Honda!
I've now been mowing with it for the past year in extremely tough conditions and it runs like a champ, just louder. I have a YouTube video showing 15 seconds before changing the gasket ( you can see puffs of smoke ), and 15 seconds after the change.
My question is: did I set the valve lash too tight maybe... Or too loose? I forget the feeler gauge clearances I used but .005 and .007 ring a bell. I can look it up for sure.
Here's a link to the video:
http://youtu.be/i0uJeZu3hT0
Thanks in advance
Thanks in advance
